跳转到主内容
The Moto E4, also known as the Motorola Moto E 4th Generation, or model numbers XT1765, XT1766, XT1767 and XT1768 was released in June 2017.
Can't send text messages until reboot.
Occasionally, my phone will refuse to send text messages until reboot. Calling is still functional. This usually happens with an uptime of >24 hours. I have tried using different messaging programs, disabling and re-enabling mobile data, and cleaning the sim card contacts. What could be causing this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @ian_ ,
Are you talking about SMS or MMS?
SMS doesn't require mobile data to be enabled, MMS does.
Have you tried using the phone in safe mode to see if it works OK?
If it does then a downloaded app may be the cause of the problem.
Just a thought.
完成的
I have only tested this issue with SMS. I have not tried using safe mode due to how unreliable the replication of this issue is, but it's existed pretty much since I got the phone. I can try putting it in safe mode for a couple days to see what happens.
完成的
添加一条评论
1个答案
I agree with jayeff, I believe its a APN issue. You can google the APN Setting of your carrier and input that into your settings to allow your phone to send certain messages.
这个答案有帮助吗?
得分 0
1条评论:
I have tried resetting my phone to default APN settings before, I should have mentioned that in the question. I did look into changing the APN values to something else, but when I try to edit them, every option besides "APN" itself is greyed out.
完成的
添加一条评论
添加你的答案
Ian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 159
