跳转到主内容
Repair guides and support for your Toshiba TV.
193 个问题 查看全部
Tv screen keeps going off but the sound still works
My tv keeps playing up, sometimes it works without a problem for hours on end and then others after 10/15 minutes the screen will gradually go black starting from the bottom and then the whole screen goes off but the sound still runs through the tv perfectly fine, after unplugging from the wall and leaving for a while the tv will come on again and work fine until it happens again. Obviously this is a huge inconvince as I use the tv frequently, any suggestions on what the problem may be ( something simple or something complex) don’t want to replace the whole tv if it is only something minor.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
You did not ask a good question: you did not specify/identify your tv model. You did not even mention its type.
If your tv is a LED-backlighted LCD panel model, then its backlight system could be failing. If you use it at high brightness, then you might be able to postpone the inevitable (total backlight failure), by lowering its backlight brightness setting.
完成的
Could also be a CCFL type with the inverter going thermal fail.
完成的
Hello Lewis, please shine a flashlight at the screen and let us know if you can see the picture. This test will help direct the diagnosis.
Cheers…
完成的
添加一条评论
1个答案
最有帮助的答案
lewis.pakeman let us know what model your TV is. Once it has a black screen but maintains the sound, darken the room and shine a flashlight at an angle against the screen. If you can make out shapes/silhouettes etc. then you know that this is a backlight issue (bad backlight array or bad power supply) If it does not show anything, it is most likely a main or t-con board situation. Again, we need to know the exact model to assist you further.
这个答案有帮助吗?
得分 3
1条评论:
@oldturkey03 its the toshiba chrome cast 2016 model The backlight goes out I turn off the tv turn it back on it works fine again sometimes it does go out again I factory reset the tv does the trick for a few weeks then goes off again what could be the issues? Thank you.
完成的
添加一条评论
添加你的答案
lewis.pakeman 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 19
总计 1,516
