Sony tv no picture has sound
Immediately after I turned power on to my Sony xbr-75x850e tv Heard a small pop. Sound came on normal but no picture. DTV box light on. TV light on. Does not feel hot. No burnt smell. Less than 1 year old
disconnect all inputs. disconnect the power cord. Hold the power button depressed for about a minute, then connect one video source. Try something like a game console or a DVD player (just in case the issue comes from your DVR box).Right now it sounds like it could be a backlight issue as well as a video issue, With the TV on and sound working, shine a flashlight at an angle(in a darkened room) against the screen. If you can make out shapes and silhouettes, it is a backlight issue. Could be a bad backlight array or bad power board. If you do not see anything it could be a bad main board or T-con board. If that does not work you may have to replace the back on your TV and check a few things. You will need a meter for that and it will help if you post some good pictures of your circuit boards with your question. Use this guide 在已经存在的问题里加入图片 for that
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 11,179
