跳转到主内容
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 个问题 查看全部
Standby flashes, backlight flickers, repeat every 10 seconds
This isn’t my exact model, but I have one that is extremely similar. When I plug the TV in, it it immediately tries turning on, the standby light blinks and the backlight kicks on, changes the brightness a couple times, then turns off. This cycle repeats indefinitely, without pressing a power button on either the TV or remote.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Cody Mort  we will need to know your exact model number. If it turns on when you plug it is then it is most likely the button bar/IR board or the power board. Remove the back of your TV and take a good look at all the boards. Check for obviously damaged components like leaking/domed looking capacitors and IC’s that are partially melted etc. Post some pictures of your boards with your question so that we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cody Mort 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 382
