Ipad does not charge battery
Goodmorning everyone. As for object my ipad does not recharge the battery. When you connect the power supply on the screen, the looped charging logo appears. What can it be?
Check that the charger you’re using gives you at least 2A, if you are using a smaller charger such as that of an iPhone the iPad might bootloop forever. Same thing happens if the battery is dead and unable to take charge. Last possibility is the iPad charging circuit is faulty but since that requires microsoldering skills should be considered as a last shore. Don’t let the Ipad bootloop in any case as that might corrupt the Nand chip and make things worse.
这个答案有帮助吗?
Buonasera, purtroppo è arrivato al 42% enon carica più... avete idee?
Odds are yet the same, a faulty battery or faulty charging circuit. Unfortunately there's no way to tell exactly without further testing.
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 70
4条评论
How long are you leaving it plugged in for? If the battery is completely drained, it may take a while before it has enough power to boot.
由 Ian 完成的
Now I try to leave him in charge. The strange thing is the looped charging logo.
由 Fabio Colombo 完成的
Do you have a PC or a Mac? Are you using a charger or a computer USB port?
由 mayer 完成的
I'm using its original power supply. Now it is completely discharged and leaving it on charge seems to have broken down .. let's see what happens
由 Fabio Colombo 完成的
