跳转到主内容
加入维修社区 - 创建账户
这是 Sony VAIO VPC-EB33FM 笔记本电脑的设备页面,包含故障排除和安装指南。
Laptop flickering Screen GPU or Screen
Hello, I have a laptop that has a flickering screen, when I connect it to hdmi monitor the screen says no signal. Is there any way to check if the GPU has problem or the screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
Hi,
Just checking that you are operating Fn + F7 to view the display on the external monitor?
完成的
@jayeff I tried but it seems like non function. Also when it tries to boot on windows, it shows just black screen.
完成的
Hi,
Do you get the Sony splash screen on start up?
Can you get into BIOS (press F2 on startup) and check if the display works OK there?
What OS is installed?
完成的
@jayeff On startup it shows the Vaio logo and I can access bios but it still does the same problem.
完成的
Hi,
At this stage you still don't know if you're booting into windows or not so maybe that's why the external monitor doesn't work i.e. the no signal message.
Since it is still flickering in BIOS and hoping for the best it could be a loose LVDS cable connection (at either end - motherboard or laptop), a faulty LVDS cable (as the cable passes through the hinge, press around the hinge area (left or right I’m not sure re your laptop) to see if you can make the flickering stop or if the screen goes black completely when you are in BIOS to see if the cable may be damaged in this area) or a faulty screen.
Here's a link to a video that shows how to dis-assemble the laptop.
Not that you have to go that far but it should help as it shows how to access the various components in the laptop.
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
Well, I swapped the screen with another laptop I had and I saw that finally @jayeff was right, LVDS cable had problem and that was the reason of the flickering screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Savvas Giannoukas 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 27
总计 4,166
