跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Missing SMD component next to the FFC connector
How to identify the SMD component
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
R1752 is a zero ohm resistor 1/32W in a 1005 package. A zero ohm resistor is usually used as a jumper link between two points. It is easier for the component insertion machine to place a component than to solder a jumper. For test purposes, I’d go ahead and use a small wire jumper.
这个答案有帮助吗?
得分 3
添加一条评论
That component is a resistor called R1752.
You can identify the component by using the Boardview and Schematic diagram for the iPad Mini 2.
If the digitizer connector got damaged during removal if you were doing a digitizer replacement for example always unplug from the short end on the left hand side of the cable to avoid damaging the connector.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John Saliba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 200
