跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
How to fix Eject sensor?
I recently purchased a used ps4 that has an issue with the eject sensor/button. The system reads and ejects discs just fine as long as I do it through the menu. So my issue is just the button or sensor. The power button and sensor work perfectly fine. Does it need a new button or could something be disconnected? Any help would be great!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You most likely have a model where the button is touch sensitive. In this case it’s usually either the metal spring that connects the eject button to the eject daughterboard is broken or bent. If it’s bent the wrong way you can bend it back so that it touches the eject board.
If it’s broken though you’ll need to replace the bottom cover.
这个答案有帮助吗?
得分 3
4条评论:
That did the trick. Thanks a ton!
完成的
Thank you very much. Worked 100%.
完成的
Hello, i have tried this however i cant tell if the bit of metal is touching? Is there a trick or special shape the metal should be?
完成的
B Wallace I'm wondering the same thing can someone help , I've bent it right down , I'm thinking maybe it's the ribbon connection or something .
完成的
添加一条评论
添加你的答案
Christian S. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 53
总计 2,770
