跳转到主内容
The Hover-1 Liberty is a self balancing e-scooter or hoverboard. It has a max speed of 7.4 mph, a max weight capacity of 160lbs, and it can travel 3 miles on a full charge. It also comes with LED wheels and Bluetooth capabilities. Model: HY-LBTY.
8 个问题 查看全部
Wheel does not seem to be straight
The one wheel on my daughters hover board is not straight and moves quite a bit compared to the other.
When I opened it up there were little black bits ??? Compared to the other side it looks like a plastic clip is missing?
Is there a way to staibilize the wheel? Hover 1 won’t help us due to the receipt is not with us as it was a gift …
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
I’d first check the bearing. Use a magnet to tell if the bits are metal or plastic.
这个答案有帮助吗?
得分 1
1条评论:
all bits are plastic and wheel goes down at last i used only 2 times
完成的
添加一条评论
添加你的答案
Les hill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 246
