2010 mac mini best ssd
best ssd for 2010 mac mini
You might want to consider swapping out your optical drive for a second drive (SSD in this case). Here’s the IFIXIT guide Mac mini Mid 2010 双硬盘安装. Here’s the needed parts iMac & Mac mini Dual Drive Enclosure and [关联产品丢失或禁用: IF107-142]
Or, you can swap out the HDD for a SSD following this guide Mac mini 2010中期硬盘更换 and you’ll need this kit [关联产品丢失或禁用: IF171-043-3]
产品
$19.99
指南
难度:
中等
55 minutes
指南
难度:
中等
1 - 2 hours
这个答案有帮助吗?
The “best” ssd’s are probably the Samsung 870 ssd’s but the 2010 mac mini uses sata 2 for the ssd connector which means that even if you get an awesome ssd, it’s not going to change the performance that much. I think a cheaper Crucial BX500 is best for the 2010 mac mini and can be found for less than $30
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,176
