跳转到主内容
Lines on right side of Screen
Hi about a week ago my macbookpro started to go crazy. Lines on the right side of the screen started to emerge. At first it was only about 1.5in but then another section started to emerge aswell. You can see it in the picture i took of it. To the left of white line in the messed up part is where the second section of the problem starts.
When i bend the right side of the screen back and left to the front the lines all disappear. At first they would go away by just tapping the screen but now it doesnt work. Pressure has to be applied to keep the lines out of the screen. Its really annoying. Sometimes those lines just become a black or white stripe. As in ONE WHOLE solid stripe. Apple said it needs to be replaced for $800. and i have no warranty. What do u think the problem is? Would it be just the cable or the LCD screen itself. I tried an external display aswell there r no lines. Screen shots show no lines either. It has to be something with the screen. But idk what to do. I want to open it up and take a look. Please tell me what to do? Also where do i find a guide from to open it up since its the UNIBODY macbookpro. got it in jan 2010.
http://tinypic.com/r/ip1kxj/7
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Please give us the last three figures of your serial number so we know exactly which machine you have. Thanks
完成的
66E is the serial number
完成的
anyone!?!?!?!?!?!
完成的
Apple MacBook Pro "Core 2 Duo" 2.53 13" (SD/FW) Specs
Identifiers: Mid-2009 13" - MB991LL/A - MacBookPro5,5 - A1278 - 2326*
完成的
添加一条评论
5个答案
已选择的解决方案
Your most likely problem is the LCD panel. It's easiest to replace the whole unit but expensive. I's look over both the installation for the panel and the whole unit. Here's the panel: MacBook Pro 13" Unibody LCD Panel
Here's how: MacBook Unibody Model A1278 LCD Panel Replacement
Here's how to install the upper case: MacBook Unibody Model A1278 Upper Case Replacement
Replace a glossy or anti-glare display panel compatible with the A1278 Late 2008, A1342 Late 2009 to Mid 2010 MacBook 13" Unibody models and A1278 MacBook Pro 13" Unibody model laptop. 1280 x 800 pixel Resolution. 13.3".图片
产品
$69.99
这个答案有帮助吗?
得分 4
添加一条评论
its your Lcd problem screen is going to finish.. try with a another whole display . it will help you to confirming which part is damaged . but from my side you macBook pro screen is damaged. change it...
这个答案有帮助吗?
得分 1
2条评论:
lcd problem scheen is going to finish? what does that even mean?
完成的
means have to change lcd ...
完成的
添加一条评论
I had the same problem. It was indeed the LCD's fault, but I found a cheaper fix: applying pressure to the control board at the bottom of the LCD fixed the problem. I made it permanent by adding a piece of thick paper between the control board and the aluminum casing. Hope this helps anyone who has the same issue in the future.
UPDATE: My cheap fix lasted for about two months and then the problem started happening again, worse and worse. It was probably a bad connection on the LCD itself. I dished out $150 for a new LCD and that fixed the issue for good. Not cheap, but definitely worth it compared to the $800 Apple would charge for the same problem.
这个答案有帮助吗?
得分 0
添加一条评论
hello, having the same problem with my macbook my serial number ends in 66d could this be a manufacturing fault on a certain batch? it seems to be a common problem with this model
这个答案有帮助吗?
得分 0
1条评论:
Yes, could be. But since there is no recall etc. on it, it will only be an academical question/answer. You still have to replace it if your is not working.
完成的
添加一条评论
hello friends !!
I have got MacBook Pro 17' Early 2011 model. In any screenshot it does not show any blue and red vertical lines but on screen it does show. What can be the reason for this ? What steps I must follow in order to get rid of this problem. Please suggest !!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 23,423
