Repair Predator FPV drone.
Started using a new Predator. Had a small hard or crash landing. Now I cannot get equal or consistent power to all blades. I’ve repeated the set up process several times but only get power to 1, 2 or 3 blades, not 4. Then, the 4th blade turns a little but not consistent. What may the problem be?
if it is the same blade every time, perhaps the motor axis is bent or the blade itself is broken
由 Albert Zweistein 完成的 分享
Can I fix that and how
由 alexrice8384318arr 完成的 分享
try to spin the fourth and the third for example motors with your hand then compare the force that you applied between them.
由 Vertinhol 完成的 分享
