跳转到主内容
加入维修社区 - 创建账户
XV40 系列 Camry 于 2006 年北美国际车展上首次亮相,同期发布的还有混合动力版本,并于 2006 年 3 月作为 2007 款车型正式上市。
p2763 code toyota blade
i AM ASKING UNDER THIS AS SON HAS TOYOTA BLADE 2007, CVT TRANS 2.4LITRE
BELIEVE ENGINE IS WHAT IS USED IN CAMRY. japanese import
ENGINE LIGHT AND VSC LIGHT COME ON DIAGNOSTIC CODE IS P2763 TORQUE converter clutch pressure control soenoid control circuit high.
do you think this is a solenoid only or clutch converter or transmission,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
How many miles is on this car ? Has the transmission fluid ever been changed ? The most comon cause for this code are plugged filter . before tearing the car apart start with a complete transmission oil and filter changer then clear your codes and drive the car and see if this corrects the problem . If it brings no joy then you will need to replace the valve and solenoid . Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
Hi ! My vehicle has a 2011 RAV4 CVT transmission. I'm getting error code p2764. RPM fluctuates at certain speeds on the road. I'm wondering if I can follow these steps. Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SANDRA 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 2,163
