跳转到主内容
A 65" rear projection TV by Mitsubishi.
7 个问题 查看全部
I am still experiencing the green blinking light issue.
No Luck! I replaced the 7 capacitors on the DM module board with 680uf 35v caps but I am still experiencing the green blinking light issue. Sometimes I can get the TV to stay on (great picture) but mostly the set shuts down after a few minutes with a bit of a thud sound. Sometimes the green light will continue to blink for hours, other times just for a few minutes.
Any ideas where to go from here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@mackaxe
This model is extremely hard to fix Mitsubishi had trouble with it from the start. When one fixed one problem a new one is next to follow somewhere else. It was so bad that Mitsubishi ended up replacing the complete chassis and quickly phased this model out. There were troubles with the EEPROM as well so maybe you can check on that as well as all the pico fuses. Holler if you need the service manual
这个答案有帮助吗?
得分 1
1条评论:
Yes, the service manual would be great. How do I get one?
完成的
添加一条评论
添加你的答案
Mackaxe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 105
