跳转到主内容
加入维修社区 - 创建账户
一款可以连接便携式键盘并像笔记本电脑一样使用的平板电脑。
bios not detecting hard disk
Ok, I have a Lenovo Flex 4 15" 2in1 laptop which I had two years but after the first year it would not fully load maybe because of connection, (maybe). Yes it will still power on. Now after some time I realized my Bios setup did not recognize are was not communicating with the hard disk . At first, thought hard drive was bad but it wasn't. Have anyone had this issue and can help me. Your help will be a blessing too me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
When you turn on your computer, it show you a message like no hard drive detected ?
由完成的
no just the name of my laptop
由完成的
Have you tried to set default settings of the BIOS ?
由完成的
when i go to bios it keep asking for password which i do not have
由完成的
添加一条评论
1个答案
最有帮助的答案
Alternatively, you can try manual methods to fix this error, but if they do not help, then you need to change the Hard Disk.
Check the data cable
Check the Jumper Setting
Check for Auto Drive Detection
Check if the Drive is spinning
Generally, if the hard disk is not recognized by the BIOS, you have a hardware failure. For example, the Hard Disk is dead. In this case, you’ll need a new hard disk.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
WILLIAM WALKER 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 41
总计 614
