跳转到主内容
加入维修社区 - 创建账户
1.4GHz 或 1.6GHz 处理器 / 64GB 或 128GB SSD
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
11条评论
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see 在已经存在的问题里加入图片
完成的
try a different dc in board
完成的
What’s that involve, is it doable myself?
完成的
the i/o board guide that trevor posted
完成的
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
完成的
显示更多的6条评论
添加一条评论
1个答案
最有帮助的答案
Two possibilities:
Most likely possibility: bad battery
2010年末 MacBook Air 11" 电池更换
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
MacBook Air 11" Late 2010 I/O 板更换
MacBook Air 11" (Late 2010) I/O Board
Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.图片
产品
$29.99
Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V).图片
产品
$49.99
MacBook Air 11" Late 2010 电池图片
指南
难度:
中等
15 minutes
MacBook Air 11" Late 2010 I/O 板图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
andy hawkins 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 13
总计 466
