跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
What do I do with the blade on a failing fusion drive?
I have a 27” late 2013 iMac with a failing (or rather failed) fusion drive. I would like to replace the HDD portion with a 2TB SSD. Do I need to remove the SSD blade? What happens in that case? Can I remove the SSD blade and not replace it? Right now I’m regretting I ever got the fusion drive. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A Fusion Drive is the marriage of a HDD and a SSD.
So at this point has your SSD part is failed or the HDD?
If the SSD failed it would make sense to replace it but I wouldn’t replace it with another small SSD and then redo the Fusion Drive. Instead I would setup standalone dual drive config where you use the SSD as your boot drive and leave your HDD as an independent data drive. While its a bit of work its worth it! iMac Intel 27" EMC 2639 刀片 SSD 替换件 It will give you the performance you really want. Here’s the SSD you’ll need Blade SSD.
If your HDD died then replacing it with a SSD while doable, can’t be joined to your blade SSD that was part of your Fusion Drive. The Faster PCIe interface of the blade SSD is ideal for your boot drive and holding your cache & paging files setup as independent dual drives.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 103
