跳转到主内容
加入维修社区 - 创建账户
Dremel 4000 是一款变速旋转工具。它兼容所有 Dremel 旋转工具配件。
Loose Wire Need Connection Point
My husband used my dremel to cut drywall. I’m sorry, ex-husband…. I took the tool apart and cleaned out as much as I felt was safe to do, but there is a wire loose that I can’t find the connection for. It’s a blue wire coming from the small board behind the speed adjustment. There is a brass “U” shaped hook on the end. Where does it hook to?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It attaches to the motor as well. The square shaped metal on the tip of the blue wire goes on a slot on one of of the sides of the motor brushes, on the plastic case. You may need to work it around to make it fit the slot. Then put the brush on the top of it.
Source: http://messageboard.dremel.com/Topic8053...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
A Moryer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 39
总计 656
