跳转到主内容
加入维修社区 - 创建账户
JBL Xtreme 于 2015 年 9 月发布,是一款便携式蓝牙扬声器,具备防溅功能。
initial charging problem and etc
I hope someone could help me, I just bought my JBL extreme 2 days ago, I did charge it for the first time. It started to charge but when it reaches 4th LED it did not charge. Then from the 1st LED it jumps to 4th LED. What may seem to be the problem of my JBL?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
now it wont fully charge. if its plugged in to the power outlet it says fully charged, same thing happened in my phones meeter(in the JBL connect). I then unplugged it and it indicates 80% power. its a defective device i guess. but i lost my receipt
由完成的 分享
Same thing happened to me, the battery on the speaker is defective. You have to contact JBL and have them replace it or you can do it yourself if that's not an option.
由完成的 分享
How do you change the battery yourself?
由完成的 分享
My speaker is turning on but not charging.. I plug the charger in and it's not charging at all.
由完成的 分享
I have changed my JBL battery and is not charging but the charging port is ok, what could be the problem
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
There are many possibilities.
Leds aren’t always accurate on electronics. But yes,that sounds extreme. It could be as simple as a bad battery. It could be a bad charger as well. I’d not those 2 things,it’s the circuitry. It could be a component issue.
If the battery life is fine,but just an inaccurate indication of battery,it could also be a faulty battery meter.
Sometimes charging until it won’t charge(keep it plugged in for a while after it hits 4th led or appears to stop charging),then drain it until it shuts off,then repeat the full charge step. In many devices,this calibrates the software meter for the battery,to make it more accurate.
have you tried using it for a while at a time? Is the battery life ok,setting aside the meter?
worse case,you could return it as defective,right? Just swap it out?
这个答案有帮助吗?
得分 2
1条评论:
yes, i have used it yesterday with an estimated 80% battery it lasted for 6 hrs with full volume. charged it for 30mins at night then played music for like 6hrs with below 20% volume and after i wake up its dead. as i wake up, plugged it in and took a shower, by the time i finished shower, the battery went 80% on my phones meeter, JBL connect app to be specific.
由完成的 分享
添加一条评论
My speaker is turning on but not charging. I plug the charger in and it's not charging at all.
这个答案有帮助吗?
得分 0
3条评论:
My JBL speaker is turning on but not charging. I plug the charger in and it's not charging at all. How can I fix it?
由完成的 分享
Replace battery. Look up guides online to replace the battery. Takes about 30 min.
由完成的 分享
I have new battery I replace it and its good but if I charge it stop on 4 level still blinking make ages to make it fulll what should i do? Do I need to drain in to calibrate.
由完成的 分享
添加一条评论
添加你的答案
jed roman malata 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 14,019
