跳转到主内容
Televisions made by the Chinese multinational electronics company, TCL.
264 个问题 查看全部
TCL TV - Red Background
My TCL when turned on has a red, speckled background, this fades but re-appears in splotches when playing???????
Update (12/04/2018)
Jayeff,
many thanks for the hints. Here’s what I’ve tried; upgrading software - none available, re-setting all, moving to a different power point, unplugging all attached & re-attaching one-by-one all without sucess.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @halserf ,
What is the model number of the TV?
Try using different inputs or signal sources (e.g. DVD player etc) to see if it occurs all the time or only from a particular signal source or input.
Post some pictures of the "speckled background" and the "splotches" so that it can be seen what it looks like.
Here's how to do this. 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
最有帮助的答案
@halserf
looks like polarizing issues and a new main board will most likely resolve this. Of course make sure that you test your TV with all input sources and check your wiring as well.
这个答案有帮助吗?
得分 3
1条评论:
Cheers for that, much appreciated
完成的
添加一条评论
添加你的答案
Ralph Halse 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 57
总计 2,960
