跳转到主内容
加入维修社区 - 创建账户
ZTE 于 2015 年 9 月发布的 5.5 英寸智能手机。
How to fix storage space running?
keeps says storage space is running. How can I fix this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @islands7
If you have a ZTE ZMAX 2 check if it has Android Ver.6.0 installed.
If not update the firmware to this version and then you can try to format the SD card as internal storage.
If you need more storage change the SD card to a max of 64GB to give a total of 80GB which is no more that what was possible before but now you can have apps on the SD card as well.
I did say try, because a lot depends on what options the device manufacturer will allow with the firmware that they use in the phone.
Also I'm not totally sure with your model that if the above works that when formatting the original SD card it might erase everything from the card so maybe do a backup first or use a new SD card
这个答案有帮助吗?
得分 1
添加一条评论
Dear Thompson,
Now a days many of user experiencing the same issue.
it can be solved easily by
  1. Adding one memory card. the move some internal memory file (Phone stored personal data) to external memory.
  2. Uninstalling unwanted application
  3. Resetting your phone (Your data will lost).
Best of Luck
For any further queries you can comment here
这个答案有帮助吗?
得分 0
1条评论:
Did not work, no advice about moving apps to SD card when no option displayed
由完成的
添加一条评论
添加你的答案
r.s.thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 437
