跳转到主内容
加入维修社区 - 创建账户
惠普推出的激光打印机。使用 12A 硒鼓,在 5% 覆盖率下可打印 2,000 页。额定速度为 15 PPM。
Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
这个答案有帮助吗?
得分 2
添加一条评论
The User Manual (which you can get online) recommends:
  • Cleaning the pickup roller with a lint-free cloth and rubbing alcohol. Just tried that and it enabled my printer to grab 3 pages one after the other (instead of jamming after just one).
  • Alternatively, replacing the pickup roller. I see you can order some on Ali Express. Haven't tried that yet.
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
这个答案有帮助吗?
得分 0
1条评论:
I replaced pickup roller $25 and still have same problem. Now thinking it's sensors, in which case, probably bye-bye printer. Otherwise, this printer has been the best tech investment ever in terms of stability, function and reliability, so missing in other gear.
由完成的 分享
添加一条评论
添加你的答案
Ellen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 2,719
