跳转到主内容
Budget 15" laptop series released by HP.
261 个问题 查看全部
Hard drive is no more available
Hi,
Regarding Repair Guide: HP Pavilion 15-bk020wm Hard Drive Replacement HP Pavilion 15-bk020wm Hard Drive Replacement :
I think the laptop and also the hard drive is no more available (only used one).
To replace the hard drive which actual model could I use?
Thanks.
Update (11/27/2018)
Model number: HP 762990-005
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Please give us the make and model number of the drive.
完成的
Please see my answer below. Thank you.
完成的
添加一条评论
2个答案
已选择的解决方案
That looks like a standard 2.5” SATA Drive. I suggest you buy this SSD as it will improve your device performance. It should work with your laptop.
这个答案有帮助吗?
得分 5
添加一条评论
Don’t worry about replacement part numbers.
Any 2.5” drive will work, but hey replace with any SSD drive.
Your computer will run better than when it was new.
这个答案有帮助吗?
得分 2
1条评论:
I agree with you.
完成的
添加一条评论
添加你的答案
Jorge 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 7
总计 387
