跳转到主内容
加入维修社区 - 创建账户
Asus Q534U 是华硕 Q 系列笔记本电脑的一员。该笔记本电脑配备 360 度折叠铰链,只需简单翻折即可在笔记本电脑和平板电脑模式间切换。
How to change a display hinge?
How can I change a display hinge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I haven’t figured out how to open it up yet, but I have found the correct (left) hinge for my Q534UXK (run dxdiag for exact model #). Note the hinges are not symetrical so you need to know which one. In my case, the “left” hinge is the left when looking at the LCD panel with lid opened up. I found the hinge here: https://www.asus-accessories.com/left-hi...|l .
Could use feedback in how to separate the LCD panel from the back plate. It appears that the hinge is secured to the top back lid/plate and the LCD is a snap fit, but I don’t want to start poking and pulling hard on the panel without being certain. I had previously dropped it and bent the hinge which impaired operation and it eventually led to the hinge connection failing due to the extra stress on the joint.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathaniel Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 653
