跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
417 个问题 查看全部
Tv wont turn on. Buzzes when its plugged in.
So i have the tc-p50gt25 from my uncle and the power supply board makes a mechanical switch noise when its plugged in. Seems normal. But when i go to turn it on. It buzzes and proceedes to flash the power light 6 times. There is a cracked screen but its been working with it for a while.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@jxsh23
the 6 blinks is a Driver SOS 1 code from the SC energy recovery circuit. You will have to check the SC board and the SC to A board flex cable. Post some images of your boards with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片
You need to let us know how is your screen is broken. It is a Plasma screen so the humming could be coming from the boards for your screen
这个答案有帮助吗?
得分 4
添加一条评论
The mechanical switching sound is likely a relay engaging. The buzzing can be caused by coil whine (normal but annoying) or capacitors that have blown.
Blown capacitors in the power board would also cause the other symptoms you mentioned.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joshua Jaquish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 2,009
