跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
wifi range very poor after disassembley
Basically i changed my iphone to a white one using one of the kits that are available on ebay, When i finished the install my iphone's wifi wouldn't pick up anything unless it's within 2Ms of the source of the wifi. After a while i took the iphone apart again as the light sensor wasn't working and when i put it back together the wifi was back to normal, I had to take it apart again to replace the home button as it got jammed and now i'm back to the same where the wifi range is extremley poor. What could be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
8个答案
已选择的解决方案
harry there are plenty of people in the same boat.. it would seem the culprit is a screw!
*The answer is one of the screws that screw the logic board to the metal body of the iPhone. In our case it is the one near the camera or the one below below the inner antenna connector, this is most probable but who knows). The screw grounds the board with the antenna!!*
Armald Imeraj, Dec 7 2010 @ 10:47 AM
wi-fi distance was reduced
Wifi very weak after display replacement
Wifi and GPS Problem
这个答案有帮助吗?
得分 4
1条评论:
do we know the exact screw?
完成的
添加一条评论
Losing the metal clips marked in green is top reason for abnormal Wi-Fi operation after reassembly.
Here are two images, which I shot, that better depict the cause of the issue. Once you lose that piece, you have no option but to order a replacement cover.
In case they don't here, here's an external link.
这个答案有帮助吗?
得分 4
添加一条评论
I run a company called fixmyiphone and we run into this problem sometimes after taking an iPhone 4 apart. This problem occurs when you touch the wifi cable next to the loud speaker unit (at the bottom of the iPhone). We have found the best way to fix this is to replace the wifi cable, this will sort all your wifi problems out.
Anthony
这个答案有帮助吗?
得分 1
添加一条评论
not an answer just a big thanks this has been bugging me for ages now. THANKS......
这个答案有帮助吗?
得分 0
添加一条评论
That little piece makes a huge difference, wow!
这个答案有帮助吗?
得分 0
添加一条评论
My screw and metal ring are there on the wifi panel, but the wifi range remains to be very very weak. Does anyone have other suggestions?
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
works 100 % thanks for the hint
这个答案有帮助吗?
得分 0
添加一条评论
Im having the same problem, but im missing a screw near the camera. Is it possible to buy a screw set for the iphone 4??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 19,659
