跳转到主内容
加入维修社区 - 创建账户
1000 万像素柯达便携式数码相机。
SD card Is Unusable
My Kodak camera wont let me use sd cards (Iv Tested it on 4 other sd cards and it didn’t work)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
Have SD cards worked before in the camera?
What error message if any do you get when fully inserting the SD card?
Have you checked that the cards are formatted and can be read, by inserting them into a card reader connected to a computer?
由完成的
Yes SD cards did work it hasn't ben able to read cards since 2015 and yes All the SD cards I tried worked on my pc
由完成的
添加一条评论
2个答案
已选择的解决方案
Your camera may be defective. A more difficult case, since its various components can fail: connectors, camera sensors, elements of the motherboard electronic media. In the latter case, the best way out will be to conduct diagnostics in a specialized center.
这个答案有帮助吗?
得分 0
1条评论:
Welp I tried, Well I maybe just gona take it apart k
由完成的
添加一条评论
最有帮助的答案
Hi,
Check that the internal storage setting in the camera is set to Auto
Go to Menu > Setup > Internal Storage.
If it is set to “Internal memory” change it to Auto and see if the SD card is now detected.
If it was already set to Auto or if it still doesn’t work after you changed it to Auto, then there may be a problem with the card reader in the camera.
Unfortunately I haven’t been able to find a service manual or a video that may help in opening the camera so that the problem can be further diagnosed.
Hopefully you may have better luck.
这个答案有帮助吗?
得分 2
1条评论:
OK,Well I better just throw it away.
由完成的
添加一条评论
添加你的答案
Matt Pin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 53
总计 6,289
