跳转到主内容
加入维修社区 - 创建账户
Dell Precision 7710 的维修指南和技术规格,这是一台 2016 年发布的强力 17 英寸工作站。
Clean under trackpad buttons
How can I get under the trackpad buttons (Not the ones attached to the keyboard) and clean them out?
I found a drop of honey right on the right-side button and some seeped in underneath. (Which makes no sense, I didn’t eat any honey yesterday and it was fine last night???)
Is there a way I can lift out the trackpad button to clean underneath?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
this might he kind of cheesy but, there is probably a guide on ifixit that will show you how to take the buttons off.
由完成的
all the ones I could find were for macs.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @roachrex ,
Just curious as to how you know that it is honey and not just some other sticky substance deposited there. You don’t have any bees around the place do you, leaving you a calling card? Just kidding ;-)
Here’s a link to the service manual for your laptop.
Scroll to p.22 to view the necessary pre-requisite steps and then the procedure to remove/replace the palmrest assembly.
The trackpad is part of the palmrest assembly.
Once you have removed the palmrest assembly you should have access to the trackpad.
I do not know if the buttons are an integral part of the trackpad assembly or not, but at least with it accessible you may be able to determine this.
If you have to replace the trackpad for whatever reason, searching online for Dell Precision 7710 trackpad part seems to indicate that it comes as part of the palmrest assembly and doesn’t appear to be available as a separate part. It was only a quick search and this may be wrong. You may have better luck in finding it as a separate part if it is deemed necessary.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Seth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 29
总计 3,575
