跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
20 个问题 查看全部
1994 vauxhall corsa/ holden barina misfiring
my Barney the Barina (that I have owned since new) decided to start misfiring if it rained… quick spray of wd40 on the distributor cap and he ran like the new again. Recently had some rainy weather, husband notices some grit in cap, sprays wd40, seems to be ok but then stalls/backfires/dies. Check distributor cap-burned out rotor, damage to cap. So far 1) replaced distributor cap, & 2)replaced rotor…still misfire. 3) replace spark plugs… still misfire 4)replace HT leads, still misfire. Barney starts, but is running rough. any Idea? @oldturkey03 ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
thanks for all the helpful replies :-)
the mobile mechanic declared the problem to be the ECU… I wasn’t convinced. Took it to the real mechanic who found that the timing belt had jumped a few teeth.
lesson learned… when the husband says he doesn’t need to check the timing belt because that couldn’t be the problem?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
pollytintop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 548
