跳转到主内容
加入维修社区 - 创建账户
TI-84 Plus calculator support.
Why doesn't my TI-84 calculator turn on
Why doesn’t my TI-84 calculator turn , I had change the batteries over a month ago or a little less than a month ago?? Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
添加一条评论
1个答案
最有帮助的答案
Perhaps the batteries died or corroded? You should open up the battery compartment to check if there are any corroded batteries. If there are, carefully remove them, clean up the connections in the battery compartment, and add fresh batteries. If it still doesn’t work, there may be damage to the motherboard from the corroded battery. You can try this guide to replace the motherboard.
If the batteries are completely fine, then you may want to refer to this amazing wiki. If it doesn’t help, you can see if your calculator still has life in it by pressing the [on] button (with batteries) and connecting it to a computer using a mini USB to USB cable. If your computer recognizes that something was plugged in, then it’s most likely the screen that has failed, the guide I linked above will help with replacing the screen. If your computer doesn’t recognize that something was plugged in, then I’m sorry, but your calculator is toast. You’ll have to contact Texas Instruments support and see if you can receive a working calculator.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
katherine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 500
