跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
A1502 won't turn on, but the track pad is clicking
I have an early 2015 macbook and it was working fine, but now will not turn on. It does nothing when I hit the power button. It does react when I do the SMC reset, but nothing happens after that either. Also, the mouse clicks when I press it, but nothing else is happening. The battery seems to be charging and when I plug the charger in it changes colors. Anyone have any ideas where I can start?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Disconnect bothe the battery and mag-safe. Press and hold the power button for ten seconds. Pul it back in and if the logic board is good, it should boot spontaneously.
UPDATE
ZAP the PRAM.
Shut down your Mac, then turn it on and immediately press and hold these four keys together: Option, Command, P, and R. You can release the keys after about 20 seconds, during which your Mac might appear to restart.
  • On Mac computers that play a startup sound, you can release the keys after the second startup sound.
  • Next hook up an external monitor and see if you get anything.
这个答案有帮助吗?
得分 3
4条评论:
Didn't do anything. You think the board is bad?
完成的
Not good but I have several more things, see update above
完成的
Hello, did you manage to get it fixed? My 2018 Macbook Pro no touchbar is having similar issues
完成的
Hey, my Macbook pro a1990 not fixing yet ! Touchbar & monitor still off but trackpad clicking , on board nothings to do fix , how can i do to fix this issue ?! I'm going to crazy !!!! Please help :((
完成的
添加一条评论
Take the back of the computer off and see if the fans run when you press the power button. Connect the computer to an external display if the fans are running and tell me if you see anything. Also, does the caps lock key light up when you press it?
Update (11/13/2018)
Nevermind the fan part. Try the external display and caps lock suggestions though.
这个答案有帮助吗?
得分 0
4条评论:
With that Macbook model fans don't start when power button is pushed..just for reference.
完成的
@arbaman Ah okay, thanks for letting me know! I learn something everyday. :)
完成的
That's the nicest thing about life, you're welcome :)
完成的
Caps lock does not come on when pressed.
完成的
添加一条评论
添加你的答案
Rudy Cooperman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 8,105
