How to make device beep when new messages
Can you please advise how to make Uniden Dect 6.0 answering machine beep when there are new messages.
Hi @ Sharon Linke,
This is from p.20 of the operating manual (click on “view operating manual” link on the page).
Go to Menu > Answering Setup > Message Alert.
“Have the system beep every 15 seconds when you have a new message; the beeping stops when you listen to all your new messages. (To mute the alert without listening to your messages, press any key on the base)”.
这个答案有帮助吗?
Thanks, that worked. Unfortunately, the beep is very soft and a long time between each beep so it won’t be heard. :(
Hi @ Sharon Linke,
Try to increase the volume of the beep by pressing the volume up button on the base station when the answer machine (and handset) is not in use.
I'm hoping as this increases the ringtone volume from the base station that it may also do the same to the message alert signal. Worth a try anyway.
Unfortunately there doesn't seem to be an option to change the periodicity of the message alert beeps. It's either 15 seconds or Off.
Here’s where to download the Users Manual:
这个答案有帮助吗?
Helped sort out the hard to find feature of turning message alert on. Many Thanks
Hi @ desantis
You may be out of luck. It appears that the system is not designed to “beep” when a new message has been stored in the answer machine. It only gives a visual display on the base station and in the handset display. There are no settings shown in the manual to turn on/off an audible indication when a new message has been stored in the answer machine
According to the user manual on p.52 in the section entitled Listening to messages:
Using the base unit
When new messages have been recorded, the message indicator on the base unit flashes. (see image below).
(click on image to enlarge for better viewing)
Using the handset
When new messages have been recorded, “New message” is displayed.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 2,582
6条评论
Hi,
What is the model number of your phone?
由 jayeff 完成的
Uniden Dect 6.0
Dect1735
由 Sharon Linke 完成的
How do I alter the message time as soon as my message playe it beeps and go off so can not leave message
由 Carol Hamon 完成的
Hi @ Carol Hamon,
由 jayeff 完成的
how do i get the answering machine to beep when a message has been left on it
由 desantis 完成的
显示更多的1条评论
