跳转到主内容
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
How to make device beep when new messages
Can you please advise how to make Uniden Dect 6.0 answering machine beep when there are new messages.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Hi,
What is the model number of your phone?
完成的
Uniden Dect 6.0
Dect1735
完成的
How do I alter the message time as soon as my message playe it beeps and go off so can not leave message
完成的
Hi @ Carol Hamon,
完成的
how do i get the answering machine to beep when a message has been left on it
完成的
显示更多的1条评论
添加一条评论
3个答案
已选择的解决方案
Hi @ Sharon Linke,
This is from p.20 of the operating manual (click on “view operating manual” link on the page).
Go to Menu > Answering Setup > Message Alert.
“Have the system beep every 15 seconds when you have a new message; the beeping stops when you listen to all your new messages. (To mute the alert without listening to your messages, press any key on the base)”.
这个答案有帮助吗?
得分 2
2条评论:
Thanks, that worked. Unfortunately, the beep is very soft and a long time between each beep so it won’t be heard. :(
完成的
Hi @ Sharon Linke,
Try to increase the volume of the beep by pressing the volume up button on the base station when the answer machine (and handset) is not in use.
I'm hoping as this increases the ringtone volume from the base station that it may also do the same to the message alert signal. Worth a try anyway.
Unfortunately there doesn't seem to be an option to change the periodicity of the message alert beeps. It's either 15 seconds or Off.
完成的
添加一条评论
最有帮助的答案
Here’s where to download the Users Manual:
https://www.scribd.com/document/11987767...
这个答案有帮助吗?
得分 3
1条评论:
Helped sort out the hard to find feature of turning message alert on. Many Thanks
完成的
添加一条评论
Hi @ desantis
You may be out of luck. It appears that the system is not designed to “beep” when a new message has been stored in the answer machine. It only gives a visual display on the base station and in the handset display. There are no settings shown in the manual to turn on/off an audible indication when a new message has been stored in the answer machine
According to the user manual on p.52 in the section entitled Listening to messages:
Using the base unit
When new messages have been recorded, the message indicator on the base unit flashes. (see image below).
(click on image to enlarge for better viewing)
Using the handset
When new messages have been recorded, “New message” is displayed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sharon Linke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,760
