跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
Can I upgrade to SSD without taking out the HD?
Dear forum friends,
I am willing to buy an upgrade kit for my iMac. I am thinking of inserting the 500 Gb SSD. My question is: do I need to take the original 3-Tb HD out, or can I run the iMac with both the new SSD and old 3-Tb HD?
Thanks
(iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit)
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit.图片
产品
$122.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Here is what you want to do:
  • Buy this upgrade bundle form OWC, this bundle has the blade SSD which is the proper SSD you need
  • Follow the guide I linked to below, you can keep your old HDD and have a blade SSD running simultaneously
27英寸iMac(EMC 2546)刀锋SSD的更换
The upgrade bundle from iFixit won't work because it comes with the wrong drive which could only go in the place of your current HDD. I understand you want to keep your current HDD, so the kit from OWC will be your best option because it comes with the blade SSD instead of the SATA SSD.
It appears that iFixit doesn't sell the right blade SSD for your iMacunfortunately. Again, OWC is your best bet because of the drive compatibility.
Update (11/10/2018)
Added by @mayer: (thank you! I would have upvoted that comment if I could)
Here’s how to set up a fusion drive on your Mac
https://support.apple.com/en-us/HT202574
这个答案有帮助吗?
得分 2
10条评论:
Thanks a lot!!
Do you know if IFIXIT also has a compatible bundle? OMC kit has a 20-day delay to ship.
完成的
Unfortunately, iFixit doesn't sell this SSD in a kit or without a kit. OWC is your best bet. Hope this helps!
完成的
Here's how to set up a fusion drive on your Late 2012 iMac:
完成的
How about this kit Aarron: iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
It's a Crucial MX300 SSD -- or is it not a blade SSD?
Thanks again!
完成的
Unfortunately that is a SATA style SSD and the blade SSD you need is an Apple proprietary drive. Again, your best bet is OWC.
完成的
显示更多的5条评论
添加一条评论
STOP!!
Atul - Sorry guy the IFIXIT drive is a 2.5” SATA drive it is NOT what you want if you also want to hold onto your current HDD.
You need a blade SSD and you need review this: The Ultimate Guide to Apple’s Proprietary SSDs
这个答案有帮助吗?
得分 1
2条评论:
Thanks Dan, how about this model https://beetstech.com/product/solid-stat... - probably it will fit, right?
完成的
Yes, that is the Apple SSD you want.
完成的
添加一条评论
No It Is Not Possible Because The Newer Models Drop Support For Dual Drives.
这个答案有帮助吗?
得分 -2
5条评论:
Even if my iMac is 2012 model?
完成的
Yes. Support for dual drives ended with the 2011 iMac. But you could get an external drive and plug it in via USB or Thunderbolt.
完成的
Uh, I disagree with this. You can have a blade SSD and a hard drive running on this Mac at the same time. This Mac may not have a optical drive but it has an SSD expansion slot on the logic board.
完成的
You need to show some documentation on this statement
完成的
A Fusion Drive is a dual drive! Its a blade SSD and a SATA HDD which you could also just run as discreet drives.
完成的
添加一条评论
添加你的答案
Atul Kumar Taneja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 248
