跳转到主内容
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Using display to display other stuff!
I've dismantled my tab3, not really worth keeping around but i'd like to know if i can use the display to display other stuff! The plan is if yes to wire it and make a wii portable but i've no clue how to wire it and if i even can
A pointer would be helpful!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ben Lang  you could with some extensive knowledge of circuit design and PCB construction. you will need a driver board to hook it up to anything else. With the case of your idea, you would need to know the output data from the Wii’s display adapter and you would need to have the input data for your Tab3 display. Without having this data etc. (in most case even with all that data) it is pretty much impossible for the normal DIY’er to do this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ben Lang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 140
