跳转到主内容
加入维修社区 - 创建账户
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
MacBook kernel panic reboots
Wondering if there’s a quick fix or a workaround
Crash Report
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi dan I have a early 2013 MacBook rentina dual graphics
完成的
添加一条评论
2个答案
已选择的解决方案
Found my workaround this fixed my issue to all who reads this this helped me out it disables the bad graphic card
http://dosdude1.com/gpudisable/
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
What happens when you boot up in Target Disk Mode? Restart your system and hold the T key, do you get the Thunderbolt Icon on your internal display?
If yes, try booting up in Safe Mode holding the Shift key what happens then?
Lastly, lets run diagnostics holding the D key when you restart. Did you get an error?
What I’m trying to do here is to locate what is failing as the crash report error is not very clear. If you can post the original text file instead of the JPEG snapshots so its more readable.
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 1
2条评论:
Ok thank you for the response well I added the text file up in the original post
完成的
panic(cpu 0 caller 0xffffff7faccc5705): "GPU Panic: mux-regs 3 0 a0 d9 9 8 severity 3 - - - - AppleMuxControl/kext/GPUPanic.cpp:149
完成的
添加一条评论
添加你的答案
tyguy764 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 119
总计 2,301
