Soldering Iron for board work
Could someone send me a link for the right soldering iron for doing work on the logic board a good inexpensive soldering iron is all im looking for with the right fine tip
这个答案有帮助吗?
I like the weller soldering irons, make sure you have a good small tip, flux/solder etc.
does this one come with a small enough tip for removing the backlight coil?
+ lemerise I already gave you the thumbs up on this. I apologize that at that time I didn't have time then to leave a comment. I have had this tab open for a few days, because I plan on buying one of these ( I need to close this tab). That is a nice little soldering iron for many of the discreet components on this board. You can get a 64th of an inch conical tip for it! I believe it may come with one if not it is the 32nd of an inch it comes with. Either way a nice little iron for dealing with small chips. My personal preference is to use hot air on boards like this, sometimes for various reasons, that is not feasible.
This little baby may be exactly what you want and cheap at twice the price: [关联产品丢失或禁用: IF145-093]
这个答案有帮助吗?
how many watts?
It always helps to actually look at a link given in an answer. 0 watts, it's Butane.
lol whoops sorry does it have small enough tips for say removing a backlight coil?
6 different tips. Tips can always be squeezed down with pliers
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 3,698
4条评论
jared...you asked this question 2 weeks ago, and you've asked about water damage and broken logic boards again.. is this an ongoing problem or different phones. I think we should merge these
由 pollytintop 完成的
Different phones
由 Jared 完成的
https://www.bestsolderingirons.com/. you can find the best soldering iron for your soldering job
由 Ellyse perry 完成的
If you are a beginner or professional, you can find the best soldering iron.
由 Ellyse perry 完成的
