跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Toshiba TV.
Toshiba 40RL938 LED Backlight Problem
Hello people,
I have a Toshiba 40RL938, which is an LCD TV with LED Backlight. Since yesterday, the backlight isn't working after 1 second. More specifically, every time I power on the TV, the backlight works fine for 1 second, then shuts down, while the TV picture is still visible if you shine a light on it. Sound works too. That means that for one second in every power on, I can see perfect image, then the backlight goes off.
Someone told me that the LED backlight is dead, however it isn't since for that 1 second at every power on, it works perfectly.
It's like something is forcing the backlight to shut down after 1 second.
I've tried leaving the TV overnight out of the power socket, and even changing a power socket, but none did work.
Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I can’t find out how to turn my backlights on, anyone know please
完成的
添加一条评论
1个答案
最有帮助的答案
@patikol
this could be a power board issues (backlight power circuit) or a backlight array failure. Yes, they will briefly light up and then shut down. Common failure would be the power board. Post some images of all of your TV’s board with your question so we can see what you see and hopefully assist you with determining which of the two has failed. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christos Kapetanios 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 2,661
