跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1148 个问题 查看全部
Head phone jack not responding correctly
So I bought this iphone from a friend who said it was waterdamge
So I fixed it by cleaning etc it has been working fine for a couple of weeks but now when I plug in my headphones in my iPhone and listen to music it pauses on it's own and once I push play it plays on the speaker instead of the headphones so do I need to replace the headphone jack if so do i order it on ebay or do i buy it here on ifixit or is the phone not working right please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
have you tried cleaning the inside of the port with a qtip? might be corrosion in the jack itself which is causing the problem..
完成的
No I havent but I also have been having trouble with the power button, it doesn't want
To respond either
完成的
添加一条评论
2个答案
已选择的解决方案
You are better off replacing the whole jack on this phone since fixing it is a cheap fix. It doesn't make sense to fix the part beyond replacing the whole cable.
Here's how to do it. Here's the part.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If you're having issues with the power button too then it may have something to do with the flex in which both the headset and power button are on. I would first check the connection of the flex which is directly under the headphone jack on the inside of the phone.
If there is any corrosion on or around the connector, clean it with isopropyl alcohol and a toothbrush. I also agree with attempting to clean with a q-tip and alcohol inside the headset port.
这个答案有帮助吗?
得分 2
2条评论:
after i clean the flex cable, how long do i let it dry
完成的
an hour or so to be sure. last thing you want is to short something. alcohol evaporates pretty quickly..you can use a hairdryer on cold setting.
完成的
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 602
