跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
one headphone is not working...
3gs 32gb have changed the 3 times powerflex but still same problem only 1 headphone is working other not. but when we take out the flex out to phone and we adjusting the headphone cable rarely i can listen both headphones are working. with the orignal flex also same problem. i already checked the logic board with the other phone . logic board is ok
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
SIMRAN, have you checked your headphones and may be tried another one?
完成的
添加一条评论
3个答案
已选择的解决方案
i have a set of bose headphones that only work at a certain position in the iphone... no matter which phone they are in.. I believe it is a problem with the jack pin on the headphones. I'd try the advice and try other headphones
这个答案有帮助吗?
得分 3
3条评论:
Simran if you are happy the logic board is ok, and you are sure the headphones are ok then it only leaves one thing that can be defective. It would be highly unlikely that 3 power flex are also defective unless you are buying from the same dealer.. ?? perhaps it is not connected properly?
完成的
i bought all from the same seller. now what to do. if we take out the flex from the phone use again then at certain point both headphone are working .
完成的
simran..if you bought 1 from the same seller and sent it back, then got another 2 faulty flex I think really you have a batch of bad flex. don't buy there again!!!! buy from another dealer, use ebay whatever, but get a refund...
完成的
添加一条评论
If one headphone is playing and the other is not, you probably just need to get new headphones. You're plugging the headphones directly into the phone, correct? Because if you are using some sort of adapter, you may have the wrong one.
这个答案有帮助吗?
得分 0
1条评论:
i m using the orignal came with this . that are working fine with my macbook pro and ipod ...
完成的
添加一条评论
You could try using a different pair and see if they work.
这个答案有帮助吗?
得分 0
1条评论:
i tried but no success ....
完成的
添加一条评论
添加你的答案
SIMRAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,652
