跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Samsung TV.
Can I fix this?
My tv will power on with a distorted pic and a loud static sound (even with vol off) then power off like it is resetting. It will eventually be alright until you change the input or turn off. When it first started it would do this for maybe a min or so. Now it will do this for over 30 mins.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Jules Ggirl  this will depend on the model of your TV. This could be a power supply or main board (most likely) issue. We need to know the model and need to know what you have checked.
这个答案有帮助吗?
得分 2
添加一条评论
Whether you can fix this TV depends on your knowledge of electronics… on your ability to solder but also to be able to remove components competently then replace them .
Their are high voltages generated inside a TV the primary side of a SMPSU (switch mode power supply) will kill even the experienced dabbler.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jules Ggirl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 68
