跳转到主内容
加入维修社区 - 创建账户
全新的 GMT900 代 Silverado/Sierra 于 2006 年第四季度作为 2007 款车型推出。它具有重新设计的外观、内饰、中框和悬架,并且某些发动机的动力也得到了提升。
Why do my speakers only work sometimes?
My truck’s passenger speaker has been going in and out. Today however, my drivers side has gone out as well. My rear speakers have never worked. I don’t know if it is a speaker issue or if it is a wiring issue. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi @devman867 ,
Is it a stock head unit or an after market one?
If after market what is the make and model number?
You may have to check the connections on the back of the unit first and then go from there.
由完成的
It is a stock head unit.
由完成的
chek the aux inbut
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @devman867 ,
It is a process of elimination to find every problem that you have with the radio/radio speakers
First test the individual “faulty” speakers with an Ohmmeter (function found in a DMM (digital multimeter) for continuity to prove that they are all OK electrically. Also inspect the wiring connections from the speaker drivers to their terminal blocks to ensure that there are no loose connections or dry solder joints. You’ll have to work out how to gain access to the speakers themselves or it may be easier to try the the test below first, regarding testing the wiring between the radio and the speakers. If you can’t “see” the speakers with an Ohmmeter then there is a break somewhere in the wiring which may be on the speakers themselves
Here’s a link that shows the wire functions of a 2010 GMC Sierra radio harness. It should be OK as it is in the range 2008-2013 which I think are all the same but I may be wrong about that. If in doubt search for (insert year model) GMC Sierra radio wiring diagram.
Here’s a link to a video that shows how to remove the radio from the dash so that you can access the wiring harness connector located at the back of the radio.
If all the speakers test OK that eliminates the speakers as the problem then you can use the Ohmmeter to prove continuity in the wiring between the radio harness connector pins (unplug the connector) and the various speakers.
If that also tests OK it eliminates the wiring as the cause of the problem then you may have to prove that the various radio speaker outputs are OK by connecting a test speaker directly to the radio output wires for ones that don’t work correctly or at all.
After that the problem is in the radio itself. It will have to be opened and the problem further diagnosed
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Devin Pounds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 41
总计 4,284
