跳转到主内容
Guides and support for various television (TV) brands and styles.
9050 个问题 查看全部
Backlight turns on with TV then off.
Hi, I got a Magnavox 40in LCD TV (40MF401B/F7) with a display problem.
When I press the power button, the tv turns on and lights up and the words “DIGITAL TELEVISION” are displayed, then the screen goes dark.
Picture is visible when a light is shined into the screen and sound plays fine. Problem persists on HDMI and Component inputs with different devices.
Vertical black lines also sometimes appear within the picture and did so before the screen stopped working. Checked tv settings and all appears normal but haven’t yet found how to do a factory reset.
Any suggestions for some diagnostic or repair steps would be greatly appreciated.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
@sylp “Picture is visible when a light is shined into the screen “ means your main board is displaying the video but you have no backlight. Check the power board for any obvious damaged components. Measure the voltage output to the LED backlight from the power board to the LED’s let us know what voltage you get (connector CN1914 Pin 1-5 should give you 24V). It is possible that this is a power board issue or a failed backlight array. Post some pictures of all of your boards with your question so that we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. It will allow us to see what you see.
这个答案有帮助吗?
得分 2
2条评论:
Hi, just in case it wasn't clear, the backlight does light up when the tv is first turned on but then it turns back off which I thought might be unusual enough to have an immediately clear cause.
My multimeter is broken but I will open it up and take a look and take pictures and pick up a new meter if I don't see anything.
Thanks!
完成的
Yes you made the backlight situation clear in your original question. Remember that it is the main board that turns it on by signalling the power board to supply the voltage. Since it turns out, your main board sends the signal. Then it turns off could be caused by a bad power board or the backlight array itself. My first suspect is the power board.....
This "Vertical black lines also sometimes appear within the picture and did so before the screen stopped working." could be a T-con board issue or a mainboard issue (less likely).
完成的
添加一条评论
I dont know if it will be the same on a lcd but i would check for an “Inverter” or “Backlit” loose connections
这个答案有帮助吗?
得分 0
1条评论:
I will check it out, thanks!
完成的
添加一条评论
添加你的答案
Sylvia Parsons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 38
总计 11,414
