跳转到主内容
The iRobot Roomba 560, an automated vacuum cleaner, was released in 2009.
14 个问题 查看全部
Why won't my roomba hold charge?
I have two roomba 360s. One won’t hold a charge for more then a minute and then it dies, the other aon’t charge at all it says “charging error 3” . How do i fix both of these problems ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
First, turn your Roomba upside down and clean the battery contacts on the base. Unplug the docking station and clean any dirt or debris off the contacts there too. If the contacts are rusty the rust will prevent the Roomba from charging properly. Get an emery board or fine nail file (I used the cardboard type as they are more flexible) and gently sand off any rust. This may get your Roomba charging again.
As this is an earlier model Roomba the battery maybe due for replacement. Even a rechargeable battery doesn’t last forever. Later model Roomba’s have software that won’t let them take non-original parts but yours might not have this issue.
这个答案有帮助吗?
得分 0
添加一条评论
I don’t dock mine, I plug it in. Now what?
这个答案有帮助吗?
得分 0
2条评论:
Battery replacement.
完成的
This rumba is only a year old and it doesn't hold a charge, what a piece of junk
完成的
添加一条评论
添加你的答案
Anglea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 6,378
