跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
White Screen of Death after Bake the iPhone
Hey guys!
Last month my iPhone´s (4) GPS started to become intermittent. Sometimes it worked, sometimes its not. As I live in Brazil and bought my phone in USA, I had nowhere to go, no warranty support, so, after tried so many restores, Cydia tweaks and long hours in open places, I decided to open the device and give it a shot, try to find some fix by myself.
I opened the iPhone and did everything I could. Disassembled it by complete (a few times) and checked every possible cause for the issue, but found nothing. So, I saw somewhere in internet about the "Oven Trick", that consists in open your phone, take out the main board (PCB) and put it in an oven for seven minutes in a temperature about 190 Cº. Theoretically, the heat can melt the solder and fix microfissures in the phone's main board. Well, seens it's true, my GPS is alive again!
Despite the GPS been' workin' fine, now I'm dealing sporadicaly with the "White Screen of Death": when the iPhone gets to sleep state and I press the "Home" or the "Sleep" button to wake it up, the screen turns to complete white, but I'm able to unlock the gadget, use the apps, play music (I can hear the sounds) and even conect with iTunes, but I can't see nothing. I'm just able to make it come back to normal opening the iPhone and cleaning the digitalizer and LCD connectors. When I do it, the iPhone works flawlessly for a few hours. If someone can help: do I'm just gettin' a bad contact and not assembled it right, or yes, I did worst and burned this part ot the PCB?
In time: hard resets doesn't help me, they do nothing but keep with the white screen. A restore was not a good option too, things didn't change. What I have to do, like I said, is open the phone and clean both connectors (digitalizer and LCD) for things go fine for a while. Last time I opened it, my camera stopped workin' too... Well, guess I'm killing softly the iPhone 4, but I'll fix it or die (I mean, kill the phone) trying!
Thanks in advance and sorry for any english mistake.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Same here i forgot to take the sim out and while i was taking the motherobard off i twisted it now when it turns on its just black lines and white screen
完成的
添加一条评论
3个答案
已选择的解决方案
Hey, Josh, thanks for replying, but I'm not that sure about the LCD, cause everything but the GPS was working fine before the oven (and I didn't touch on it (LCD) to remove the main board). One thing I noticed is that the issue is related to the charging process. Sometimes the phone was working great, and just after charge it or connect to iTunes, the "white screen" started to appear.
So, last night I did something that I had not done yet: let the battery completely dry and put it to a full charge. So far so good, the iPhone is working fine since then, there's just 30% of charge right now and no white screen untill this moment. Hope the issue has gone, but I'm not all confident about that, since I didn't test connecting to iTunes (I charged the phone at the wall plug). Guess I'll let the battery dry by complete again and then let it charge and sync with iTunes. Let's see what's gonna be! Thanks again for the attention.
这个答案有帮助吗?
得分 0
添加一条评论
could just be a damaged lcd, if you can hear the sounds and use the touch screen
这个答案有帮助吗?
得分 0
添加一条评论
Take the iPhone apart enough to check the screen connector and reassemble, it could just be loose and reassemble the phone, see what happens
iPhone 4 屏幕总成更换
If it doesn't work, it's damaged and needs to be replaced like Josh said
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pois0m 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,268
