跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
20 个问题 查看全部
After shutdown battery won't hold charge
After shutting down my iPhone 5 I realized it’s battery went to 0 and stayed there. I’ve been charging it for 1-3 months but no success has occurred. Can you find an answer to this problem? It won’t matter by Christmas cos’ I’m getting a £49 phone which actually looks nice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I don't understand anything about this issue.
How can you realize its battery went to zero when the phone was shut down?
Why would you be charging your phone for MONTHS at a time? And why can't you remember if it's one, two, or three months? That's a heck of a spread.
And if you're so excited about getting a new phone, why worry about this one?
完成的
Why don't you stop complaining eh? It's been a year, that phone could've been up and running, next time give a suggestion. The world is already &&^&@@ up.
完成的
添加一条评论
1个答案
The 5 series has an issue with the U2 IC (charge control microchip). They can often be damaged with aftermarket charge cables. If you have a ammeter, such as the portapow, you can see if the phone is actually pulling a charge or not.
The issue could also be the battery itself. If it is worn out too much, it won’t hold a charge and could be causing the issue as well
这个答案有帮助吗?
得分 0
1条评论:
I guess that's kind of the problem, the phone died after holding a few months of bad broken charging cables and it seems to be the capacitor causing the issue. Thanks!
完成的
添加一条评论
添加你的答案
BlueBlue 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 61
