跳转到主内容
加入维修社区 - 创建账户
Asus ROG Strix GL702VM-BHI7N09 是 Asus 于 2017 年 1 月发布的一款游戏电脑。
What's wrong with the GPU?
Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.
I’ve tried a fresh install of Windows, a different drive that I know is fine, different NVIDIA drivers. So I’ve narrowed it down to the GPU.
I’ve done some runs of Furmark, and each time, when it gets to >75C it usually blue screens or freezes with blocks/stripes of green/white/purple, and if it doesn’t do that on its own, a reasonable tap on the keyboard where the GPU chip is causes it.
Is this a sign that it needs BGA reballing by a repair shop, or is it a more serious less-repairable issue?
Thanks in advance for any help :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Joe McKinnon try some GPU throttling and see if it makes a difference. Root cause for this is poor airflow to keep things cool. https://rog.asus.com/forum/showthread.ph...
完成的
添加一条评论
1个答案
最有帮助的答案
Yep, “Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.” thats a sign of a dying/deadGPU. If the GPU in this machine is modular and can be replaced it is a simple and relatively inexpensive fix if you have the right part. However, if the GPU is soldered to the motherboard that would require a motherboard replacement which is by far not the easiest thing to replace and it will be costly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joe McKinnon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 398
