跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
How can I install the operating system on MBP mid 2009?
Hi everyone,
I have a MBP mid 2009. It was running sluggish. I pulled the hard drive out and formatted it in Windows. Since I did that, I am not able to install any kind of operating system on it. I don’t even have recovery and internet recovery isn’t available on my model.
What can I do to fix this? I have spent 4 days trying to figure it out. Tons of online reading. I have tried creating bootable USB’s with Mojave, Leopard, High Sierra, and El Capitan.
I’m a windows person and I have no idea how to get out of this mess. Any help is welcome.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You’ll need to download a copy of the El Capitan to install it. Find a friend with a Mac to help you. as you’ll need to use his system to setup an installer thumb drive following this guide: How to make a bootable OS X 10.11 El Capitan installer drive
这个答案有帮助吗?
得分 1
9条评论:
Can you update Lion once it's installed?
By Linux, do you mean something like Ubuntu?
完成的
The end of the road is Lion for this system. See for your self in the link I posted.
Yes, Ubuntu would be much better!
完成的
Thanks. If it helps, I looked up the serial number on the bottom of the mac and it is this model:
https://everymac.com/systems/apple/macbo...
完成的
Well! Thats not the system you had picked. While it's a newer system its limited to OS-X 10.11.x El Capitan as the last supported OS
完成的
@danj I tried to install High Sierra on this model with the Dosdude patch, without many hopes and just for fun..surprisingly everything seems to work fine and, despite 4Gb RAM only, runs pretty well. Honestly I didn't expect that.
完成的
显示更多的4条评论
添加一条评论
“I have a MBP mid 2009. It was running sluggish. I pulled the hard drive out and formatted it in Windows. “
I’m curious, why did you use Windows to reformat a Mac drive?
Target disk mode to reformat this in a Mac, then as long as you find the correct OS, or Linux distro, you can reinstall an OS. Good luck.
这个答案有帮助吗?
得分 0
2条评论:
Thanks. It's just what I'm used to. I've always used Windows. This was given to me and I wanted to learn how to use a Mac OS.
完成的
gotcha, good luck and happy learning.
完成的
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,660
