跳转到主内容
加入维修社区 - 创建账户
Fin stack sensor location?
Hey there. I have a 2013 11” macbook air a1465 with fans that run on full and CPU limited at 800mhz. Apple diagnostics reported fin stack sensor below limit. Is this sensor located on the logic board or the dc in board for this model? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
While this might not be your issue it should guide you on what to look for: 13” MacBook Pro - 820-3115 runs slow (Th1h Fin Stack sensor failing)
The I/O board has the sensor on it near the heat sink heat transfer fin.
这个答案有帮助吗?
得分 2
2条评论:
Ok so from reading that it sounds like the problem is connected to the main logic board. Thanks
完成的
Yes, Apple re-uses there SMC design. So it reasons it’s the same here.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 3,187
