跳转到主内容
加入维修社区 - 创建账户
Protocol Dronium Two 是一款遥控 (RC) 玩具无人机,具有银色的 X 型中框机身和四个黑色转子叶片。它配备了一台高清 (HD) 摄像头和可充电电池。
How do you replace the large gear?
My Protocol Dronium Two has some stripped teeth on one of the large gears that mesh with the small motor gear. I have got a replacement gear (and shaft). Does the gear pull off the shaft? and how hard?? Seems very tight. Does the shaft need to be replaced also, it does not seem to be damaged. Not sure how hard to pull on the gear?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
After the propeller is removed, I pulled/pryed on the propeller hub very hard but carefully to pull it off the shaft!!!
Then the shaft and gear slipped out of the housing very easily. There is also a metal shaft bushing that slid out as well.
One of the parts I purchased had a gear and shaft attached so I used that. I also replaced the small gear on the motor shaft as that had some wear on it as well. That pulled off hard (but much easier that the propeller shaft) .
The motor shaft was smooth, were as the prop-shaft was knurled on the ends, thus making for a much tighter fit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 325
